1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#688122 10/21/2010 7:15 PM
Y
Y Offline
On my 57, it has an external turn signal switch/flasher assy. It has TB 12-16 on it,assuming model #. It has 2 yellow,1 black, 1 green, 1 red, 1 blue, 1 gray, and 2 gray/black wires. The blue wire goes to the light bulb in the switch. Anyone help me figure out how to wire this into my new harness? (Upgrade harness) Which color wires are for what? Thanks.
yousa #688123 10/21/2010 7:21 PM
see this tip - your new harness may have the factory 6 wire plug at the edge of the dash where the column mounts which should have factory colors as shown in the wiring diagram here, just need to tie in the turn sig wires there
