| | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 8 New Guy | | New Guy Joined: Oct 2010 Posts: 8 | Just finished replacing both inners and outers in my 46 Big Bolt. Maybe everybody knew this but me. I got blank looks at all the local stores including NAPA. I then went to the original specs and got the original Hyatt numbers (144527 for the inner and 144525 for the outer) then to the Timken cross reference page which led me to Timken nos. KD12051-Z for the inner and KB11786-Y for the outer. The local Advance Auto Parts store was able to get them for me. Seals were another challenge but got them from Jim Carter, part #ME677. Had some stripped lug nuts but the local O'Reilly store supplied them for $.49 each, part # 814-015. As usual, getting parts at reasonable prices was a bigger challenge than the installation. | | | | | Joined: Feb 2010 Posts: 477 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 477 | Hey: Welcome, I tried to buy new front wheel bearings for my 46 2 ton and timken said they could make them for like a $1000. I finally found a used one at a junkyard in way cross. Someone on this site probably would have a better source. This was pre Stove Bolt | | |
