| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | Ok, I know the first thing to go is memory and everyone knows it been a ton of years.
I just want to replace all my brakes, wheel cylinders, master cylinders and brake shoes.
I thought all you had to do was loosen the adjustment screw and the drums would slide off. I tired this on the left rear and must have turned it a dozen times and it dosen't seem to be working. Now it has been a long time since these drums were removed.
Have a I forgotton something or doing something wrong here? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GeneBrownlow, please remember to tell us what year and size of truck you're asking questions about, that way we can make specific suggestions. Your adjusters may not be working, your linings may be stuck to the drums, your return springs may be broken. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Also, the drums may be "rust-welded" to the rear-axle hubs (depending on your year/model).
As 3B posted, " . . . tell us what year and size of truck you're asking questions about . . . "
You also might consider listing you model(s) of truck(s) in your Profile ("My Stuff" menu-item above; then "Edit Profile").
| | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | Sorry, It is a '59 Apache 1/2 ton. The drums rotate freely. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy GeneBrownlow, thanks for the info. As tclederman has said, your drums may be rusted to your axle flange, or even more common, rust between the drum center hole and and the axle may be holding the drum. Hammering between the studs on the drums flange surface may help to loosen it up, some penetrating oil sprayed around the axle studs, and the drum center hole wouldn't hurt either. Sometimes there is a groove worn in the drum by the brake lining, this will allow the drum to only move a small distance before the high spot on the lining encounters the regular bore surface of the drum, in order to remove the drum you must back off the adjustment until the lining clears the drum bore, good luck. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I am not sure about your year/model (but 3B would be); however, some models had a recessed screw holding the drum to the axle flange.
As usual, 3B's advice is excellent. Please let us know how it goes.
| | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | I know its been a few days but i wanted to get back and let everyone know silly i felt when all it took was a bigger hammer. No big issues here the drums were just really rusted in place so i use penatrating oil and after a day or so i just whacked it pretty hard and they popped right off.
I do have another question though. When i took them in to have them turned the guy told me they were worn to far. I am buying a new set of drums and never had a need to replace any before. I assume i can just bang the center hub out of the front drums and install new races and seals, right?
Thanks again for all your help. This is a great site. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Up front, you'll need to remove the rivets tat hold the drum to the hub. It's not too hard to do, they can be cut off easily with a chisle, then the knocked out with a punch. The hubs should come right out. You won't need to replace any races, unless you are installing new bearings. Only the seals would need replacing.
Bill Burmeister | | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | Do i have to rivet the hub back to the new drums?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. They are really there for holding the drum and hub assembly together when the truck was built, not necessary otherwise.
