2 members (Uncles51, Lostbuthaulinass), 79 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#686195 10/14/2010 8:32 PM
I have a friend who's working on a 72 long bed. He took out the two piece drive shaft because he preferred a solid one. He got one from a salvage yard and had it cut to fit his truck. Problem is when he goes over 40 mph it vibrates wildly. Another shop verified that the work was shoddy on the first drive shaft. He had recently bought a late 70's Buick for parts and as luck would have it, the drive shaft in it fit perfectly, but it vibrates at even lower speeds (around 25). He said that he had driven the parts car home and there was no problem with the shaft. Any ideas on this one? He did have 20" rims on all fours but switched back to the originals.
Robert C.
I'm a Genius in the making.
1950 3600
Mobileortho #686197 10/14/2010 8:44 PM
U-Joints perhaps. I assume there was no vibration before he removed the old shaft.
~Jim
BIG CHEVY 3600 #686201 10/14/2010 8:50 PM
He said he drove the parts car home and didn't have any problems.I asked him about the u-joints and said they were good.
Robert C.
1950 3600
Mobileortho #686215 10/14/2010 10:11 PM
What is the pinion angle now? If it's more then -2 degrees he could have some vibrations.
Some people say I suffer from insanity, in reality, I enjoy every minute of it!
Cracked_Head #686276 10/15/2010 12:56 AM
I am guessing that the two angles are not equal and opposite with the one piece setup. That would cause a problem as described.
1951 1 Ton Completed
truckernix #686359 10/15/2010 6:27 AM
Could be that the driveshaft is out of time with the rearend and trans. Meaning that it needs to be clocked 1/2 turn out from where it is now.
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
PapaJ #687119 10/18/2010 4:44 AM
I agree with PapaJ, My 1990 Chevy was taken to the local Chevy dealer and a "new" rebuilt trans installed. When I took it home, around closing time, it vibrated at a certain speed. Don't remember what speed but it was low. I took it back the next morning and was told there was nothing wrong. Well two dealers later a shop manager, who happens to own a beautiful 1955 Chevy car, rode with me and told me to go on and bring the speed up. Around 80 to 90 mph. Bottom line. drive shaft was 1/2 turn out. Fixed the issue and no trouble since.
1949 Chevy 1/2-Ton ~ Red Truck
