| | | Forums66 Topics128,196 Posts1,057,396 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 7 New Guy | | New Guy Joined: Feb 2010 Posts: 7 | Hey guys, I am getting ready to spray a customers 50' 5 window this weekend or early next week and I am just wondering what type of sanding tool/block you use to sand the beltline on these AD trucks. the problem is that if you use any form or hard block or even a paint stick the center of the belt seems to get flattened due to the fact that you never really get to sand off center because of its size. The other problem is the top cowl to beltline transition: it seems to be very easy to san a low in the transition area as this is where your block hits from both directions. Just wondering what you guys used... Thanks Cole | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You don't want to sand by hand in large flat areas because it can leave lines that show in the final finish, so a block is a must for a fine finish. But, in a small compound curved area like the belt line, I would just simply hand sand it with a fold of paper. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I HATED sanding that part!
Use a good, flat paint stick for everything except your final sanding before paint, but the trick is to sand in a diagonal "X" pattern from the top to the bottom of the beltline. That way you'll not leave any flat spots.
For your final sanding before paint I used a semi-hard rubber block with 400 wet. For the parts that curve around a corner you can just use your hand but always work in a diagonal "X" pattern. | | |
