4 members (Shardean, Tstan7, 2 invisible), 94 guests, and 4 robots.
Topics128,022
Posts1,055,353
Members48,420
#685835 10/13/2010 8:51 PM
I am putting a 454 in my 62 chevy lb..Do they make a radiator that will handle it and bolt in on the stock mounts?Thanks all
TULSA62 #686028 10/14/2010 6:41 AM
Aftermarket aluminum radiators are available from Summit, JEGS, etc. You can also get, what are referred to as "factory-reproduction" units, but they are not that close to original, however many of them will install, using the factory lower & upper radiator saddles. You can get them from LMC Truck, Classic Parts, Truck & Car Shop, etc. Also, many of the fast-food variety auto parts stores, like O'Reilly, Advanced, etc, sell an aftermarket reproduction unit. They are also available from NAPA.
A good four core would be a good option, especially with a properly fitting shroud, or better yet, a high cfm electric fan, would be a good combination for keeping your 454 running cool.
Good luck and keep us posted on your bbc swap.
Tulsa:
Check out this discussion.
Regards,
Steve
New Orleans
https://www.stovebolt.com/ubbthread...;Main=94834&Number=656997#Post656997
sclor #686229 10/14/2010 11:04 PM
A F**d Big block radiator my fit, it has bracketry in the verticals that allow for spacers or to be bolted to the radiator support.
