| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | working on my 46 1/2 ton and need to get the steering box removed. used a 6" 2 jaw puller to try and remove the pittman arm from the steering box shaft and no go no way. soaked it in kroil and still no luck. bigger puller? odl mechanics wizardry? unfortunately heat is not an option right now as i dont have access to tanks at the moment. any help is much appreciated.
big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You'll need a pitman arm puller, rather than a jaw tpe. The pitman pullers won't slip off as easily, and can put more force on it. Try putting some tension on it, then a few whacks with a hammer, preferrably a brass head hammer, pull for tension, whack it again. Should pop off, literally, so watch out. Done them many times like that.
Bill Burmeister | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Bill is right, the pitman puller looks like an upside down u-shape with edges that fit under the arm, and a big bolt going through the canter to push on the shaft. And they do pop off with a bang! Good luck! | | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | Thats the correct tool although probably a wimpy version for ten bucks, the snap-on version is much more expensive, but for a one time deal the HF is probably a good bet, cheap enough if it breaks. | | | | | Joined: Aug 2010 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 46 | Thats the correct tool although probably a wimpy version for ten bucks, the snap-on version is much more expensive, but for a one time deal the HF is probably a good bet, cheap enough if it breaks. I went cheap on the tool because I will use it only once or twice in its lifetime. For me the decision to go cheap correlated with return on investment. Others will disagree.
1958 Apache Shortbed Fleetside
| | | | | Joined: Jun 2010 Posts: 215 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 215 | no disagreement here, makes good sense! | | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | thanks to all.....am on my way today to get a pittman puller.
| | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I had to remove mine recently and took it by my alignment shop and they removed the nut and struck the bottom of the steering arm hitting straight up with a large ball peen hammer. On the second hit, it poped out. Don't hit the arm from the side, only from the bottom. If you have the HF puller, obviously that is the way to go. John | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | When using the pitman arm puller, loosen the nut on the pitman shaft that holds the arm on, but DO NOT remove the nut. Leave it on the pitman shaft a few turns so when the pitman arm "pops" loose, it will be contained to the shaft, possibly causing some damage to the person pulling the pitman arm or to something near the truck, or even the truck itself. No need to learn the hard way when you have someone telling you this who did learn the hard way!
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Just a FYI. Autozone rents the pitman arm puller for free.. Of course you have to put like $12 down, but bring it back whenever your done and get your cash back.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | |
