0 members (), 348 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
Guys,
I know that up to a certain point of cam lift and duration you can run the stock exhaust manifold on the Chevy 6 (or any engine). But approximately when do you run into problems with cam/lobe overlap?
I have a very mild cam in my 292 (194I/204E duration at .050 and approx .464 valve lift on intake, .490 on exhaust). I currently have tube headers (won't make that mistake again) but recently ran into a great deal on an NOS 292 factory exhaust manifold. This will work great as the Offy 4 barrel intake was cast to work with the stock exhaust.
Should I be okay here, or go with Stovebolt's split cast iron exhaust?
-ftyler
This is hard to answer with a definite quote. When you order a new cam from a good grinder they will want to know about vehichle weight, gearing, induction, desired rpm range, along with engine size. One thing for sure, it does no good to try to put into an engine with cam and carb, what you don't have enough exhaust system to get out.
Evan
There are two stock exhaust manifolds that I've seen on the 292. One has two studs, the other 3 studs, the difference is 2" and 2.5". Which one did you score?
Larry
I don't own a vehicle that isn't old enough to drink.
but the split manifold sounds so much nicer!
"It ain't a truck if you can't hose out the cab."
Larry,
I have the true 292 manifold that's generally used in larger trucks - it has the 2 1/2 inch rear dump. Plus the individual exhaust passages are larger.
Chester,
Not necessarily so. It depends on what type sound you're looking for. I personally don't like the "split six" sound - at all. I prefer the deep low, "near v8" sound. I believe that using the single manifold, along with keeping my single in/dual out Flowmaster, will preserve my current "near v8" sound that I have gotten with the long tube headers.
-ftyler
true enough. i have always liked the sound of a mild cam.
Riding in the Passing Lane
The stock 292 manifold with 2" outlet is very restrictive. The exhaust will run very hot & burn out gaskets & warp manifolds when used hard. The 2 1/2" would work better but are pretty rare.
1972 Chevy c10 Cheyenne Super
Wrenchbender,
Yep, you're right. That's why I got the 2 1/2 incher. If I work up the nerve to try a homemade lump ported intake and mild (4-71) blower on my next 292 build then the manifold may have to go.
-ftyler
