| | | Forums66 Topics128,163 Posts1,056,920 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 22 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 22 | Greetings, I am new to the forum as well as being new to truck restoration. I have a 1950 3600 wooden dump-bed truck and I am looking to update the rear end to something easier to find parts for. I plan to swap the front axle with one from a 1/2ton truck and upgrade to 5 lug disk brakes. What would be the best replacement for the rear axle? I would like to get about 3.42 ratio and have 5 lug wheels disk or drum brakes - dose not matter. I would also like something that is fairly easy to bolt right in (shock & spring mounts). I was thinking about a mid 80s 1/2ton chev rear. What will fit?
| | | | | Joined: Oct 2010 Posts: 22 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 22 | I would like to keep the 8 lug stuff too, it just seems that wheel cyl. and drums are very difficult to find and for the orig. rear. I want to keep it as orig. as possible, but I want a reliable driver. I intend to pull a trailer with it and I will be adding and overdrive transmission. So I really need the stopping power that comes with modern brakes do deal with todays crazy drivers. I have also considered 6 lug wheels as well and I will continue weighing my options. Thanks! | | | | | Joined: Oct 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 56 | Do a search for some of my posts. The Eaton rear end was used from 1946-1970. The dropout carrier until 1972. I updated mine with Bendix brakes. I did all the hard work/research. Now all you need to do is copy me. Mine has 13" brakes on the back. ALL parts are 100% NEW, not rebuilt. I got a 4:11 carrier out of a 68 Chev 4x4. It bolted straight in. Keep the Eaton rear axle. It is full floating and a real monster. Very tough. I will help you in anyway I can answering questions. Please ask. PLease see link below: http://s859.photobucket.com/albums/ab158/Duntov85/1952Chev3608/ | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Astro vans all have 5 lugs. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Astro vans all have 5 lugs. Actually, the last 3 years of Astro/Safari van production used 6 lug.
Bill Burmeister | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Thanks Bill, my brother has had a bunch of them and his newest is an '01 and it has 5 bolt wheels. Don | | |
