4 members (Gdads51, Bill Hanlon, Joe H, chemanic), 82 guests, and 3 robots.
Topics128,101
Posts1,056,339
Members48,441
OK I have a small block chevy. Need to know if I need a short shaft or long shaft water pump. This is going in my 48 1/2 ton 3100.
Also what is the best source for a great radiator.
Tom
48 Chevy 3100 Shortbox 5 window
"The Big Dog"
Several things to consider.
1. How much room between the front of the engine to the radiator?
2. Do you already have brackets for the motor to mount accesories? if so for long or short pump.
3. Electric fan or belt driven?
I went with a long pump on my 39 but I set the motor back as far as I could. Only about 1/2 inch between distributor and firewall. I also had to run different valve covers than I was originally going too.
As far as a radiator I had mine built by PRC, it was about $500 but it is a great product. No cooling issues at all and Im running a mechanical fan with no shroud.
Short pump, always. Never heard a swapper say, "darn, this engine is too short". One drawback is that the last short pumps in cars were in 1968 and 1972 in trucks. This means you usually have to buy new (repro) brackets and they can be pricey. Still it's a lot easier to use spacers and fan shroud that to modify a space to take something too long.
Evan
I have clearance for a long pump but I'm going to change over to a short pump .I like the idea of more clearance.
I agree on the short pump How much differance is there?
Tom
"The Big Dog"
I went with the "short" pump on my SBC swap & I went to
a elect. pull fan because it is somewhat "crampted" under
the hood, I went with an Amer. Radiator HD unit. (I had some
over heating problems & this cleared things up for me !)
Make sure you use a good aftermarket mount, both front
& rear, they are cheap & make things quite easy for you !
See either Classic Parts (# 79-405 for $55 (or Brothers ).
Here is your problem if you set the engine to far back (with
a longer pump) is getting the dist. in & out !
'53 GMC "Ranger"
