2 members (artinva, Chip O), 112 guests, and 2 robots.
Topics128,072
Posts1,055,904
Members48,429
#683600 10/06/2010 5:06 AM
Here is one of the pistons I pulled out of my new engine. This is the engine that was setup to power a saw mill and the PO said it was a fresh rebuild. I'm beginning to believe him. What do you think? This piston was cleaned with only a paper towel and never washed with solvent. Dave
http://travel.webshots.com/photo/2367468960101947398tbophf
http://travel.webshots.com/photo/2754660890101947398WjVrZx
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
IT doesn't look like it was ran long.
should have left it in. grin
That was one of the good ones, 5 and 6 had water in them and 3 had some rust also. I'm going to pull more tomorrow, maybe more not so good pictures.
1941 Chevy
Riding in the Passing Lane
Looks good to me. The water doesn't come from the pistons. If the head gasket looks good & there are no cracks the water may have come in from the weather or condensation.
1972 Chevy c10 Cheyenne Super
I think the water came in through the carb and down into the cylinders I believe. Dave
1941 Chevy
1941 Chevy
Give things a good scrubdown with solvent and a stiff-bristle brush, and hone the cylinders just a little with a button hone. Wash them out with hot, soapy water and rinse well, then reassemble it. I don't even think I'd replace the rings- - - - -they look brand new. If you want to be absolutely sure, do a re-ring job, but don't worry about rod bearings.
Personaly if it was me I would put a set of rings and bearings in it. Clean it up like they said. I am partial to cast iron rings in six cylinders but that is just me.Just pulled out a 261 that had lots of miles on it after 18 years and it just started to smoke a little. You would not be able to do that with a set of chrome rings for sure.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
