6 members (GMCJammer51, 55shaker, Greg_H, Bill Hanlon, mick53, 1955 1 Series), 103 guests, and 1 robot.
Topics128,198
Posts1,057,269
Members48,466
how does the steering box come off the end of the steering shaft and the tube on a 55-59??? im trying to get it apart so i can get the column out of a cab
the tube doesn't separate from the box, it comes out in one peice. You have to remove the pitman arm and steering box bolts, then the whole assembly is remived from the engine side of the firewall. It is much easier to do with the left side fender and inner fenderwell removed.
Bill Burmeister
