| | | Forums66 Topics128,204 Posts1,057,288 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 6 New Guy | | New Guy Joined: Aug 2010 Posts: 6 | how does the steering box come off the end of the steering shaft and the tube on a 55-59??? im trying to get it apart so i can get the column out of a cab | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | the tube doesn't separate from the box, it comes out in one peice. You have to remove the pitman arm and steering box bolts, then the whole assembly is remived from the engine side of the firewall. It is much easier to do with the left side fender and inner fenderwell removed.
Bill Burmeister | | |
