0 members (), 80 guests, and 1 robot.
Topics128,049
Posts1,055,741
#682858 10/03/2010 4:34 PM
Y
Y Offline
I bought a 57 3100, which someone previously added disc brakes to the front. Does anyone know what years, vehicle they use for calipers and pads in these conversion kits? I need to replace the calipers.
I'd take your calipers to the parts store and match them up against Camaro and Chevelle calipers from the 70's. Those seem to be the two most common sources used by the kits.
You might also google any numbers you find on the calipers. Sometimes a casting number will return a part number and description.
A third option would be ask the person you bought it from...
Is it the stock axle or a subframe? If it's independent suspension with a subframe, I second it that they're likely Camaro, Nova, or Chevelle; very common/cheap.
Y
Y Offline
Stock frame. 72 camaro calipers appear to me a match to what I have. The previous owner didn't do any of the work, so I can't find out much from him. Would have to dig a little deeper.
Gray haired parts guy that can use a parts catalog, can help you out. Usually they can match your casting number on your caliper with casting numbers in the back of brake catalog.
Brian
1955.2 3100 Truck
