0 members (),
38
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68217 11/06/2006 2:40 AM | Joined: Sep 2006 Posts: 26 Junior Member | | Junior Member Joined: Sep 2006 Posts: 26 | A friend has two different 3/4 or 1 ton GM 14 bolt differentials available. The first thing I did was get the numbers off the axle tubes, one has RHR G1542 and the other has KHN G0161. I did a lot of searching via google and on the bolt site and the only thing I could come up with is the RHR unit appears to be a 72 1-ton model with a 4.57 ratio.
I can find nothing when searching for the KHN model.
The next thing we did was to count revolutions. This is where things start to get screwy. One wheel was on the ground and the other wheel was in the air. For the diff with a 4.57 (RHR) when I turned the wheel one full revolution the pinion turned 2.125 revoltions. How that correlates to a 4.57 ratio is beyond me.
When I turned the wheel on the KHN diff one full revoltion the pinion turned 1.6 revoltions.
Can anyone explain to me how the information relates to diff ratios?
Brad | | |
#68218 11/06/2006 3:31 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bkahler, because one wheel was on the ground the differential was involved, so basically you need to double your readings to come close to the correct ratios, hope that helps. | | |
#68219 11/06/2006 12:59 PM | Joined: Sep 2006 Posts: 26 Junior Member | | Junior Member Joined: Sep 2006 Posts: 26 | Wrench, thanks for the info. Based on your description that would make the KHN unit something like a 3.2 or 3.4 ratio. Unfortunately that would be to high for my application. I'm looking for a 4.10 gearset.
Brad | | |
#68220 11/06/2006 5:16 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | 2 X 2.125 = 4.250
But it is more accurate to count the pinion revolutions per two full turns of the wheel. | | |
#68221 11/06/2006 8:34 PM | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Geeze I just count the teeth on the pinion and the ring gear. If I am gonna buy a rear end I am gonna open the cover before I pay.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | |
#68222 11/07/2006 1:53 AM | Joined: Sep 2006 Posts: 26 Junior Member | | Junior Member Joined: Sep 2006 Posts: 26 | Baldy,
Your 4.250 is close to the 4.57 that the RHR is supposed to be. But to low for my application.
Toyvo,
I will be pulling the cover off any diff that I plan on buying but I'd sure like to have a good idea of what to expect before doing so. My friend probably wouldn't appreciate the mess I'd make pulling covers like that.
Brad | | |
#68223 11/07/2006 3:42 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by bkahler: I'm looking for a 4.10 gearset. I have one of those. But you can't have it! It's under my 1-ton pickup and it's going to stay there.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#68224 11/07/2006 2:28 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | For your 4.10, you will be looking at 41 teeth. | | |
#68225 11/08/2006 2:29 AM | Joined: Sep 2006 Posts: 26 Junior Member | | Junior Member Joined: Sep 2006 Posts: 26 | OldSub, where do you live..?.... truckernix, thanks for the tooth count. I'm going to call my friend and have him pull the cover possibly this weekend and see whats inside. Thanks, Brad | | |
#68226 11/08/2006 3:24 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Originally posted by bkahler: OldSub, where do you live..?.... I'm 2,384 miles northwest from Jefferson. Its the black truck sitting out front. The neighbors have some big dogs. Just ignore them.
#68227 11/08/2006 4:38 AM | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | The gear ratio is base on the number of teeth on the ring gear/the number of teeth on the pinion gear, i.e. 41 ring gear teeth/10 pinion gear teeth = 4.10 gear ratio. With the cover off to check the ratio, also check the gears for a good mesh pattern. Additionally, check the gear oil for any sign of suspended shavings. Also, grab the backing plates and pull them in and out to check for excessive slop. A good deal on a 14-bolt with 4.10 ratio, can be be a bad deal if the rearend requires a new ring and pinion master setup. Good luck with your search and I hope this information is helpful. | | |
