2 members (Barry Martak, lumbersawyer), 139 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#682062 09/30/2010 6:37 PM
The speedometer on my ’53 3600 swings widely (up to 20 mph) when I am driving a constant speed. Sometimes it stays fairly stable but not others. What could cause this and what would be the cure?
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
Speedo cable binding up- replace speedo cable
1953 Chevy Two-Ton
More pix on Photobucket
Be careful calling yourself a expert,because an "EX" is a hasbeen and a"SPERT" is a drip under pressure.
You can lubricate the cable if you don't want to spend the $$. But it's a dry cable doing it. It should also be making a whining noise as it binds inside the casing. If I remember correctly you unscrew the cable from the back of the speedo and can pull the cable out from there w/o breaking it free from the tranny. We used white lub on the cable as we pushed it back in. The last little bit you need to turn the cable to get it to match up to the tranny. Then just re-attach it to the speedo. Of course if it's all rusted this ain't gonna work.......
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
You can also use graphite powder inside to lube the cable.
1953 Chevy Two-Ton
It is a new cable but I assumed that it was lubed. My mistake.
Thanks for the feed back.
It's new and it wasn't lubed? Hmm, I guess I should lube my new speedo cable before installing it. So you literally pull the cable out of the casing? Is it hard to pull out?
if it's a new cable, that's not the problem, it's the speedo itself gummed up - I wouldn't use any kind of grease on a cable, dry graphite only and only if you're sure the cable is binding, which would mean you got a defective new one
I pulled the inner cable out and lubed it, reinstalled and test drove. It works fine now.
Mine did that. I took it to a speedometer shop. They said the only thing bad with it was the odometer. They put in a new odometer that was close. The numbers weren't centered perfectly, but the speedometer/odometer worked great even past 90 mph when I buried it.
Mine does that, lubricating the cable did nothing, still does it.
If the bearing in the head is stiff the speedo will just read slow. If the head is in decent shape then just replacing the cable probably isn't enough. The cable housing wears inside and allows even a new cable to flop around. This is usually the cause of a bouncing needle if lubricating it doesn't help. You should replace the cable and housing at the same time.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
