| | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Is it possible to purchase original style or looking spark plug wires for a 57 Chevy 3100 with a 235 engine?
Thank you,
Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The ones I bought from Chevy Duty a few years ago were original style without boots. I don't think that I would go back to them though because of the lack of boots at the plugs. | | | | | Joined: Mar 2008 Posts: 374 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 374 | I got mine from Jim Carter and they work great. | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Big tee, Great looking truck!
Thanks guys!
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | This guy can make original style wire sets. 235 spark plug wires I have not purchased any so cannot "Testify" Just sharing Good Luck | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | DAD, Is that what they looked like originally? Yikes! Not to pretty! Maybe YNZ has them...
Thank you for the link!!
Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The wires in that pic look like early style or something the rat rod guys would run. He has other styles of wire jacket. I’m not sure what style your year truck had originally, My 50 had the black lacquer type. I bought the kit classic parts sold , I ran them for about 20 minutes. It was quite a shocking experience. I quickly tossed them and got a set from CARQUEST. They are a gray color wire with boots. Good Luck | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hi all, I contacted SoCalConcepts via email and the owner Roy got back to me with this info: "they are 7mm plug wire and its yellow with red and black cross traces the ones I make where commin in the 40's and 50's the only thing that changed is the boots for the mid 50's and post which I can add the choice is yours" Not sure if I will buy them as he wants $65.
YNZ does not make wires....FYI
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | those yellow stripe wires were not "commin" in the 50's, the 57 would have had black plug wires with the straight plug boots [look for pics in your manuals], you should be able to find a set at a FLAPS like thisBill | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Thank you Bill, I sorta figured that GM would not do anything fancy on these old farm trucks.
