| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 19 Apprentice | | Apprentice Joined: Sep 2009 Posts: 19 | I have the 3 speed OD tranny out of my 57 Chevy stepside and want to clean the sludge out of the inside before reinstalling. I really don't want to completely disassemble unless I absolutely have to. I will be replacing the seals. Can anyone recommend a way to flush without ruining the insides? Thanks in advance.
Mike | | | | | Joined: Feb 2004 Posts: 29,750 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,750 | Those transmissions are usually as tough as a two dollar steak. Just pour a couple of quarts of kerosene or Diesel fuel in, and spin the gears. If it's out of the vehicle, find a drill motor big enough to clamp onto the pilot bearing area of the input shaft, and spin away! You're not going to harm it at all by circulating a solvent in it, and whatever doesn't drain out will evaporate pretty quickly. In the vehicle, I just drain the old lube, fill with solvent, and run the engine with the tranny in neutral for a few minutes. Jerry
| | | | | Joined: Sep 2009 Posts: 19 Apprentice | | Apprentice Joined: Sep 2009 Posts: 19 | Thanks Jerry, I'll give the kerosene a try. I just didn't want to ruin anything in the process.
Mike
| | | | | Joined: Oct 2009 Posts: 419 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 419 | Those transmissions are usually as tough as a two dollar steak. That must be PRETTY DARN tough. I haven't had the opportunity to sink my teeth into either. But I do appreciate learning this information. Thanks.
