8 members (Peggy M, Donf, Otto Skorzeny, Wickedbass, Hawkman, NJC, GRNHydra, hdgeren), 83 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#680459 09/25/2010 3:49 PM
Apprentice
Apprentice
I have the 3 speed OD tranny out of my 57 Chevy stepside and want to clean the sludge out of the inside before reinstalling. I really don't want to completely disassemble unless I absolutely have to. I will be replacing the seals. Can anyone recommend a way to flush without ruining the insides? Thanks in advance.
Mike
Those transmissions are usually as tough as a two dollar steak. Just pour a couple of quarts of kerosene or Diesel fuel in, and spin the gears. If it's out of the vehicle, find a drill motor big enough to clamp onto the pilot bearing area of the input shaft, and spin away! You're not going to harm it at all by circulating a solvent in it, and whatever doesn't drain out will evaporate pretty quickly. In the vehicle, I just drain the old lube, fill with solvent, and run the engine with the tranny in neutral for a few minutes.
Apprentice
Apprentice
Thanks Jerry, I'll give the kerosene a try. I just didn't want to ruin anything in the process.
Mike
That must be PRETTY DARN tough.
I haven't had the opportunity to sink my teeth into either.
But I do appreciate learning this information. Thanks.
Dave
The Blue Funk: a '51 3100 4 OTF with a '57 235
More pix on Photobucket
