1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#68034 10/31/2006 5:56 PM | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | I have replaced the Hei on my 261 with a newer unit and have forgotten how I timed it the first time. Is there a way to use a standard timing light to get the optimum timing position? | | |
#68035 10/31/2006 6:17 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | here is another choice click here Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#68036 10/31/2006 7:01 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Blacksmithdon,
I think a conventional timing light will work fine. Most lights require only a + and - hookup, along with either a direct connection to #1 plug wire, or attaching a inductive pickup around #1 plug wire.
I don't know if your engine has timing marks on the damper, or still has the flywheel/peephole arrangement, but the timing procedure would be almost the same.
I'm not sure if your question was about the timing light, or how to actually time your engine? Maybe someone else will be along with more information.
Stuart | | |
#68037 10/31/2006 7:13 PM | Joined: Jan 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 62 | Well of course that's how it is done! I really need to think things through better. Thank you. | | |
