| | | Forums66 Topics128,050 Posts1,055,670 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | I got my '59 Apache running this weekend and realized that I installed the wrong fuel pump. There is an extra vaccum line from the fuel pump through the firewall. I also have the normal one that goes from the carb intake through the fire wall.
Now I know that only the windhield wipers use vaccum. I searched through all my manuals and can't find the reference to dual vaccum anywhere. I am sure you guys must know the answer to this and it would be helpful to locate some schematics for how this is setup. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | They most likely join under the dash. The idea of the additional vacuum is to aid wiper performance. If you're never out in the rain and don't need good wipers just cap the line that connected to the fuel pump.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Intake manifold vacuum to one side of the dual-action fuel pump and the other side of the dual-action fuel pump to the vacuum wiper motor.
If your fuel pump is not labeled as to which port goes where, do it one way and check it out and, if that does not work, then do it the other way.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Not sure why you'd have 2 lines through the firewall unless a PO had a vacuum guage installed in the cab. Guess you're going to have to get upside down inside the cab with a flashlight and spend some quality time getting acquainted with what's really going on in there. | | | | | Joined: Jan 2010 Posts: 60 New Guy | | New Guy Joined: Jan 2010 Posts: 60 | Should the vacum created from the dual action fuel pump be adequate for the gear change assist? Jianis | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Jianis, I'm not aware of any factory vacuum gear change assist. It may be after market. Post this question in engine and driveline with more details on it and maybe someone will have heard of one. | | | | | Joined: Feb 2004 Posts: 29,769 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,769 | I believe the vacuum shift assist was only on the late-40's passenger cars. I've never seen that option on a 1950-up car or any of the trucks. Jerry
| | | | | Joined: Jan 2010 Posts: 60 New Guy | | New Guy Joined: Jan 2010 Posts: 60 | Cletis and Jerry
I had the idea that the 1/2 ton tracks from the 40s had it as the passenger car did . The truck I am rebuilding at the moment is a 48 Fleetmaster passenger car that was converted to a truck witch had a vacuum shift assist ( that was before it was stolen...) Thank you
Jianis
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Jianis, I think they discontinued the vacuum assist because it wasn't a good idea. It could be a big headache to maintain. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Let's get back on topic here. Thanks.
My guess is someone replaced the original dual action fuel pump with a single function one. They then plumbed the wipers to the manifold and left the original line in place. | | |
