| | | Forums66 Topics128,151 Posts1,057,001 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | Hmm....I'm going to have to get going on the truck I want to build. I love the dually idea, but more people are doing them and I don't want to build what has become common It looks like you do some great work. It sits lower than what I am planning on, but I love the nice heavy frame you are using, definitely beats 2x3 tube, and looks a lot better as well. Something I look at now whenever I look at a rod is how they do the front steering. It's really hard to see in pictures, but did you get the steering set properly when putting the drag link in front of the axle. If so, how did you do so? See http://www.nationaltbucketalliance.com/tech_info/chassis/ackerman/Ackerman.asp for what I mean. Keep up the great work.
1946 Chevy OS 1.5ton, 1955 GMC 3100, along with other various IH,Ford,Nash,MGB,.....
| | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | I have yet to sort out the Ackerman... But its on the long list of things to do... Basically when you flip the drag link to the front the point where it meets the steering arms needs to be out (wider) than the point of the king pins... I'm going to fab some temporary arms and when I get the Ackerman dialed in I'm going to heat and bend the original ones to match...
Thats the plan anyway... Although I have been contemplating just fabbing up some new beefy ones and calling it a day...
As far as the dually rods... I have yet to see one in person so not very common... The ones I have seen on the net generally use modern chasis which ruins the look of the industial nature of the old trucks... The old tall skinny bias ply tires are going to be what really finishes off my truck .. Going to be running tall wide white walls, And usually the modern front ends are much wider which I think ruins the look...
| | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | Very cool, I like it!I think the motor is too modern and too short in length. Nice job on all the fabrication.Thanks for sharing , keep the updates coming. Cheers | | | | | Joined: Mar 2009 Posts: 186 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 186 | thanks, i wanted to go with a straight 8, but it wouldnt have fit i would have had to make the front end alot longer.. | | | | | Joined: Aug 2009 Posts: 184 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2009 Posts: 184 | Yeah I have only seen a couple dually rods and they have all been online as well. Glad to hear you already thought about the steering. The last show I went to I think about half of the cars there with the drag link in front were set up wrong. Can't wait to see the finished pictures
