5 members (Dennys28, Steelonsteel, Opelika Tom, Guitplayer, Ponchogl), 120 guests, and 0 robots.
Topics128,134
Posts1,056,401
Members48,441
#680180 09/24/2010 11:55 AM
Anyone ever experienced their oil pressure gauge, oil line, leaking? How hard is it to get a wrench on the line to tighten it up? What size wrench? Seems like a tight fit getting to the back of the gauge cluster.
Disciple
it is even for me and im slightly wider than a 16 penny nail. as for the wrench, what ever fits. patience is the key here. lay on the floor of the cab and weasel your way up there with a good light and take a look to see whats up and address it. it would help if you had a helper to get you what you need to minimize how much weaseling you have to do once your in position.
another way is to pull the speedo cable and remove the speedo and then you have a hole to see through with limited access.
If you can't get it to stop leaking and it is just a casual driver, the old timer fix was to wrap an old towel around it and change towels as needed. This, however is not practical if you have a bad leak.
Pulling the speedo cable and speedometer sounds like it could work. I have been wiping the oil and it seems to be getting worse, so have to get on it. Thanks for the advice.
Disciple
