| | | Forums66 Topics128,186 Posts1,057,315 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 25 | Hey guys, I have a '41 3/4 ton. I initially planned on putting my '69 Olds 442 rearend under it and making a parallel 4 bar suspension. I was wondering, since the '69 rear is a triagulated 4 bar suspension, could I just use the stock mounts from that rearend and build bars to attach to the frame? Anyone see a reason why this wouldn't work? TIA! Dan | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You'll find that the angles will be incorrect to make it work properly. The stock spring mounts also do not make for good control arm mounting points, saw someone try that on a mid-'50s Olds. He almost lost the rearend from under the car when the mount broke free from the frame. The factory spring hangars are not designed to handle the side loads that a trailing arm suspension create.
Bill Burmeister | | | | | Joined: Jun 2009 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2009 Posts: 25 | Thats all I needed to know. Thanks Bill.
Dan | | |
