3 members (1955 1 Series, Bill Hanlon, 1 invisible), 361 guests, and 4 robots.
Topics128,160
Posts1,057,054
Members48,463
looking into replacing the factory 1953 GMC 1/2ton every replacement one is 1 inch.
The factory ones are 1 3/16 dia. has anyone ran into this problem?
Last edited by Woogeroo; 09/27/2010 10:22 PM. Reason: added marque/model/ton rating to topic
Josh
Nielsen #678688 09/18/2010 9:52 PM
Riding in the Passing Lane
An old Napa catalog show's the front at 1 1/8 & the rear at 1 in.
1972 Chevy c10 Cheyenne Super
i found the wheel cylinders on a 47-50 gmc 1/2 ton. so Im leaning towards the rear end isn't factory. but i got the cylinder on the right rear to come to the front after a little work and cleaning, cant even tell it's from the 50s now.
Josh
Nielsen #679426 09/21/2010 12:19 PM
Do 47-50 1/2 ton GMC trucks use the same wheel cylinders as the 1953 GMC 1/2 ton (Huck vs Bendix brake systems)?
Not even close, in size and design.
Last edited by tclederman; 09/21/2010 12:26 PM. Reason: looked up 49 vs 53 1/2 ton wheel cylinders
