1 members (TrknGMC),
121
Mod | | | Forums66 Topics128,052 Posts1,055,774 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Hi guys. Before my VR was mounted to the firewall with some sheet metal screws. I have since ordered some new screws from Classic, however these have rubber and a screw. I am wondering how these go together?
It looks like the VR is not supposed to touch the firewall??
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | The original had rubber cushion rings in the 3 VR mounting plate holes with a metal insert. So I'm guessing, yes, it should not touch the firewall.
Drew
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Any one have some pics of the installed screws?
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | Those rubber grommets are only shock mounts- - - -the regulator housing still needs to be grounded, usually with a wire running back to the generator housing so it doesn't have to depend on body/chassis/engine ground straps. Jerry
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Have a pic? I get what your saying, but a pic would be awesome
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | These are called Well nut's. The rubber goes in a hole & when the machine screw is tightened down it swell the rubber to tighten it in the hole. This protect's the regulator from distortion & vibration. Like previous said you must have a ground wire.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Thanks for the pics. The Red photo helps alot. Looks like all 3 screws are the same size on this regulator. On mine, the screw on the drivers side(lone screw), needs to be much larger in size than the other two? Maybe mine is missing a washer or something?
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | OK I was thinking of the later models that are mounted on the core support. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Installed the way you mentioned. Just added a washer to the nut for the drivers side. Those compression nuts work great.
Now for the grounding wire. Didn't see any pics of how people grounded it. Where would I connect the grounding wire? One of the nuts that holds the lid on?
On another note.. I ran the motor with it connected last night. 10 years ago it worked fine(its been sitting, prior to the rebuild of the truck), last night it was showing 12.53v on the Bat, 1.3v on Arm, 1.3V on F(I think it was F, the small wire). Didn't see it charging? Maybe the battery was full?
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | You should see 13 volts or more at the battery posts with the engine running at fast idle or above. The ground wire should attach somewhere on the metal base of the regulator, usually by a sheet metal screw into the base. One of the cover attaching screws will be OK, though.
Try polarizing the generator by connecting a jumper wire from the Bat. terminal to the Arm. terminal on the regulator momentarily. You should get a moderate amount of spark, not a dead-short flash. Run the engine and check the voltage at either the Arm. terminal of the regulator or the battery posts. They should be within a few 10ths. of a volt of each other, and 13 volts or more if the generator is charging. No charge- - - -try grounding the Field terminal at the regulator. This should put the generator into full charge, no voltage control at all. Don't rev the engine too high with the field grounded- - - -I've seen voltage go above 20 volts. If there's no charge with the field grounded after polarizing, you've got generator problems. Jerry
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Thanks for the tips. I went back out and checked as you said. It does show charging with the (F) - grounded, however its more 12.5 volts and slowly climbing to 12.8 after about 2 minutes.. It hasn't started charging the battery on its own yet, but I guess that is due to the battery being almost full. I will have to keep a eye on it when I get the truck put back together more so I can load the accessories, lights , etc.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Update: Removed the screw/rubber nut on the driver side hole and placed a bolt there instead to ground it to the cab. Now its charging all the time 13+ volts.
1950 Chevy 3100 Blog w/Pics - http://txchevy50.blogspot.com/Goal: Clean, Rebuild, Paint, & Drive on a budget. Major restore of components will be done over time. | | | | | Joined: Feb 2004 Posts: 29,772 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,772 | So, you obviously didn't have the regulator housing grounded to the generator body with a separate wire like I reccomended. Relying on body-to engine grounds through things like the driveshaft, etc. is very risky business. They can change resistance anytime you hit a bump, etc. Jerry
| | | | | Joined: Aug 2010 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2010 Posts: 81 | Yeah, I did the bolt as part of your suggestion to ground the housing. It obviously fixed the issue. Running a separate wire is the next step, just ran out of time the day I was working on it. Electrical is only about 50% done on the truck currently. :-)
