2 members (dt235sd, JW51), 204 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#678787 09/19/2010 4:13 AM
ok put new hood hinges on today but still can't get them to work properly. The hood is hard to open and close like it's in a bind especially the last 6 inches before it closes. Actually ruined a new hinge forcing it closed. Doesn't appear to be hitting anything what gives ????????
phnman23 #678788 09/19/2010 4:16 AM
Is this on a 1923 model?
phnman23 #678793 09/19/2010 4:26 AM
59...sorry
phnman23 #678798 09/19/2010 4:59 AM
Y
Y Offline
What happens if you operate the hinges without the springs? Did you open and close hinge while removed? Some repop parts are junk! Any possibility they're mounted wrong? Have you lubed/greased them? Often new parts have to be "worked" to get them to loosen up. Hope something here helps. Let us know how it turns out.
Riding in the Passing Lane
I'm with Yaki. The joints must be binding. You need to lube the joints & work them a bit to free them up. I put some repo's on my 58. I had to elongate the holes some to get the back of the hood down far enough & i changed the weatherstrip on the cowl to something softer. It works & fit's real good now.
1972 Chevy c10 Cheyenne Super
same thing without the springs... can't really operate them by hand when removed either... I'm with you I think they are junk, the right one already has play in one of the rivets allowing the rear of the hood to stand like a wore out one!
It also looks like the holes where they bolt to the hood are off a little side to side maybe thats causing them to bind? Was afraid to alter them but what the hell there not working as is and it's only money right?
phnman23 #679015 09/20/2010 1:15 AM
greased the springs and worked them by hand until they freed up a little, seem to be better will try with the springs on tommorrow
phnman23 #679063 09/20/2010 3:38 AM
Where did you get the hinges? I just bought a set for a 58 from LMC and they worked very well.Lubed them and worked then up and down prior to installing the springs. I also changed the seal to some weather striping. The after market seal was to thick.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
hankrags #679227 09/20/2010 7:56 PM
used to be Chevy Duty now called Classic Parts I think
phnman23 #679231 09/20/2010 8:23 PM
Another thing I remember. I wound up using the old springs. The new ones were so stout it would pull the hood up in back.
