8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible),
181
Mod | | | Forums66 Topics128,086 Posts1,056,094 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | ok put new hood hinges on today but still can't get them to work properly. The hood is hard to open and close like it's in a bind especially the last 6 inches before it closes. Actually ruined a new hinge forcing it closed. Doesn't appear to be hitting anything what gives ???????? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | What happens if you operate the hinges without the springs? Did you open and close hinge while removed? Some repop parts are junk! Any possibility they're mounted wrong? Have you lubed/greased them? Often new parts have to be "worked" to get them to loosen up. Hope something here helps. Let us know how it turns out.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I'm with Yaki. The joints must be binding. You need to lube the joints & work them a bit to free them up. I put some repo's on my 58. I had to elongate the holes some to get the back of the hood down far enough & i changed the weatherstrip on the cowl to something softer. It works & fit's real good now. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | same thing without the springs... can't really operate them by hand when removed either... I'm with you I think they are junk, the right one already has play in one of the rivets allowing the rear of the hood to stand like a wore out one!
| | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | It also looks like the holes where they bolt to the hood are off a little side to side maybe thats causing them to bind? Was afraid to alter them but what the hell there not working as is and it's only money right?
| | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | greased the springs and worked them by hand until they freed up a little, seem to be better will try with the springs on tommorrow | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Where did you get the hinges? I just bought a set for a 58 from LMC and they worked very well.Lubed them and worked then up and down prior to installing the springs. I also changed the seal to some weather striping. The after market seal was to thick. | | | | | Joined: Dec 2008 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 36 | used to be Chevy Duty now called Classic Parts I think | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Another thing I remember. I wound up using the old springs. The new ones were so stout it would pull the hood up in back. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
