2 members (Otto Skorzeny, Rusty Heaps), 134 guests, and 2 robots.
Topics128,101
Posts1,056,182
Members48,436
I have attached the email exchange I had with pertronix in regards to my 6 volt pertronix module and converting to 12 volts. They say due to the type of coil I have (pertronix flamethrower) I do not need a ballast resistor in front of the coil. They say the coil itself has is a 12 volt and has a built in resistor to manage the ingition module.
Does that sound right??? I would prefer not to fry my ignition but if I don't need a resistor I would prefer not to buy one and mount it on the firewall.
I attached the email trail with their specific comments. (it reads from the bottom up)
Thoughts???
_________________________________________
Pertronix
Rich, just to let you know ballast resistors do not come in 12-volt / 6-volt
"models". They are rated by the amount of resistance they produce. Example;
you can purchase a 1-ohm, 1.5-ohm, 2-ohm etc resistor. To answer your
questions, no resistor required. The resister is in the coil itself.
__________________________________________
me
so I should still put a 6 volt ballast resistor in front of the coil right?
Any recomendations on type?
Pertronix
Rich, a vast majority of the time there are no issues doing this. The coil
you are using is actually the coil we would recommend for 12-volt systems.
Me
It is a 1167N6 electronic ignition
The coil is a 1.5 ohm part number 40011
Pertronix
Rich, I will need to know the part numbers of both the Ignitor kit and
the coil to advise you.
Me
I have a 53 truck with a 6 volt generator and a 6v negative ground pertronix
ignition with a flamethrower coil. I am contemplating installing a 12 volt
alternator. Can I keep the current pertronix set up if I put a ballast
resistor in front of my current 6v pertronix flamethrower and ignition
module to keep the feed power to the coil at 6 volts.
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
sounds pretty clear to me, there is no resistor needed with your setup because it already has the correct resistance for a 12V system built into the coil
That solid state system is not the same as the old points system. The only choice you really have is to take their word for it or buy a new 12 volt setup.
1951 1 Ton Completed
