| | | Forums66 Topics128,169 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I have a few ideas but wanted to hear from others. I need to get the threaded shackle bushings out of my frame. Any easy ways to remove and replace?
Bruce
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If they are not completly wore out, screw an old shackle pin in part way & wack it with a big hammer. If the parts are to worn for that you need a bushing driver. A socket will work sometimes. The C clamp type ball joint tool is the best way but not many have one. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Yep, I was just looking at an OTC 5038 press. It costs a bit of money but might be worth it. I'll probably see if any of my friends have one.
Bruce | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | A BIG C-clamp and an assortment of deep sockets will handle a bunch of pushing-pulling chores as long as everything stays in a straight line. Just don't let it get out of line or pieces start flying in all directions.
I used to install walking-beam bushings in Hendrickson suspension systems where the diameter of the sleeve around the center bushing was approximately 6". It was all a 50-ton hydraulic press wanted to handle to get one of them moving, and progress was a series of 1/4" jumps over an 8" total length. Installing two walking beam bushings occupied most of an 8-hour shift AFTER the beam was removed from the rear axle assembly! Jerry
| | | | | Joined: Sep 2008 Posts: 137 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 137 | We used about a 12" piece of rebar (stuck in the hole from the inside of the frame) and a sledge hammer. It took quite a few whacks but it finally came shooting out. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Harbor Freight Ball Joint Removal Kit I bought this at a 1/2 price sale and it is quite useful. I think you'd have to make an adapter to work with the spring bushings (if someone has successfully used it with a spring bushing, let us know). Here is the $5 bushing removal tool described in the thread at the link I gave above. The tool is a stouter version of the DYI Bushing Puller Tech Tip. Taking out the old bushings was a piece of cake. Unfortunately, this tool has no warranty. | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Got um out! I really didn't want to spend $90 for a ball joint press and decided I didn't want to chance a cheap one from Harbor Freight. Then DUH!!! I work for the county so I borrowed one from the local county highway shop. Popped them out this morning and pressed in two new ones. Without the press I don't think I would have gotten them out. Even with the press it was a chore. Now on to the next task.
Bruce | | | | | Joined: Feb 2000 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 38 | Pays to work where they have the equipment we need! Glad it "worked out" for you. | | | | | Joined: Nov 2008 Posts: 179 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 179 | Don't you hate when you have a "DUH" moment? | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Don't you hate when you have a "DUH" moment? Unfortunately I get used to them!
Bruce | | |
