| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | I picked up a 55 car 235 engine. I need a bell housing and flywheel, to get this thing fired up on my garage floor. So what year car or truck parts will I need to look for, that will bolt up to this engine?
TIA. Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Depends on what you are going to put the engine in? The bell housing from any 216, 235, 261 and early V8 will fit. | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | The car and truck bellhousings will both bolt on, but I believe the car type won't have bolt holes for the stomp starter linkage. Be sure and match up the flywheel and starter, for either 6 volt or 12 volt- - - -the tooth spacing is different. Jerry
| | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | The early V8 bellhousing will fit the 194-292 6-cylinder engines, not the 216-261 types. Jerry
| | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | you will need a 235 flywheel and matching starter,216, 235, 261 car or truck bellhousing,, but i don't think a v8 bellhousing will fit as was previously mentioned. good luck. garyg
our garage is a non-profit organization
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | ???
It is not just an issue of the clutch housing being able to bolt to the engine/block. The donor clutch housing should match the style for the year of the recipient truck. (Yakimabowtie's question is pertinent.)
The 1953 and earlier truck 216/235 clutch housing has a different motor-mount angle (and different motor mounts) from the 1954 and later 235/261 truck's clutch housing.
Also, I think that some 261 clutch housings might have been set-up for a hydraulic clutch (and maybe the throw-out bearing fork on the opposite side)? I dimly recall that I could not use my 1960 big-truck 261's clutch housing in my 1954 1/2 ton truck.
Brian, did your 55 truck not come with a clutch housing??
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | First off thank you all for your replies.
Yakimabowte----Not putting the engine in anything, I'm putting it on the garage floor.
Tim,---- Yes my 55 truck has everything, but I don't want to tear it apart.
All I want to do is fire this engine up and see if it's any good.(it'll be a spare engine). All I need is a flywheel, starter, and bellhousing. I know that 55-59 235 car or truck will work. I just need to know what else will work, to help in my search. "I won't" be using these parts to bolt it in my truck.
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2004 Posts: 29,798 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,798 | Just about any 216-235-261 bellhousing, flywheel, and starter will work, from the mid-40's to early 60's, as long as you don't mix up years and get a mismatch between the starter and flywheel. I think the early 40's flywheel had a different number and/or spacing on the crankshaft bolts. If you're using the car bellhousing, the solenoid-type starter would be needed, since there's no provision for the stomp start on the car bellhousings after 1948 or so. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Jerry, How will a 216 clutch housing (bell housing) work in a 1955 truck? The clutch housing has a different angle for the rear motor mounts. And, because the motor mounts are in a different location, the 47-53 rear motor mounts are a different design relative to the 54-84 rear motor mounts. The shape of the rear motor-mount frame cross-member changed in 1954 (that is why no frame cross-member and transmission mount was needed after 1954 for manual transmissions). Yes, of course a 6v or 12v clutch assembly should be used, depending on which is intended to be used in the 1955 truck | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Tim, I think that Brian is only looking to set the engine up so that it can be run on a stand, not necessarily installed in a truck at this time. That being the case, what the bellhousing is won't really matter, as long as it bolts up to the engine itself.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | OK, thanks, Bill HRL covered it nicely.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1937-62 bellhousing 1941-62 flywheel, with matching 6 or 12 volt starter.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Bill has me figured out, and the rest of you gentlemen have given me enough information now, that I have a sense of direction. Much appreciated!!!!
Brian
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2010 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 127 | Jessica's TruckThe true definition of insanity: To do the same thing the same way repeatedly and expect a different result each time. | | |
