6 members (Woodcmiami, MNSmith, Otto Skorzeny, Guitplayer, Lostbuthaulinass, Gray_Ghost), 61 guests, and 1 robot.
Topics128,057
Posts1,055,812
I would like to pull the solid line out but also save it it and reuse it. Itlooks like it has been rivited in from what I see, do I cut the rivits and move on or?..............
what solid line, do you have a pix
Redryder pix
My Hotrod
You never pull the outer tube from the cast housing. The drive shaft and pinion come out if you remove the three set screws that have the lock nuts.
My Blog
