| | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | I broke the head off one of the two bolts that fastens the rod that goes through the cowl and is bolted w/ the 2 bolts on top of the radiator support on my '46, 1/2 ton. The radiator is out of the truck. I drilled through the bolt and was hoping to use a tap to remove the rest of the broken bolt. Of course I drilled the hole off center. I can see lines inside the bolt indicating the hole is close to the threads. What can I do next? The only thing I can think of is trying to colapse the bolt with a small cold chisel. The bolt is 3/16th I think. I was going to borrow the right size tap from a machinist friend. I don't have a welder and there's none of the bolt above the hole. Thanks for any advice. Jacques
Union, Justice and Confidence
| | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | Are you sure about the 3/16? I would suspect 5/16. If you are close to the threads, it might be possible to collapse it. If not, you might want to run a 5/16 bit through it and then tap it to 3/8X16 and drill a 3/8 hole in your bracket. | | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | crenwelge, I'm not sure about the size. I'll measure it. I can borrow a small oxy/acetylene torch if needed to heat it up. Thanks
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | Once the hole is off-center, it's nearly impossible to correct the mistake. I'd suggest getting a Dremel tool and some diamond-coated bits, and try to get the hole centered back up. Proceed VERY carefully, and when the hole is close to the minor diameter of the threads, use a tap to chase the remains of the bolt out. If you try to force a bigger drill bit through, it will wipe out the threads, and you'll need to either tap the hole for a bigger size bolt or install a heli-coil. Use a very small abrasive bit at high speed, and a light touch, and you might be able to center the hole up without doing any more damage. Good luck! Jerry
| | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Thanks, Jerry. I guess an, "Easy-Out" wouldn't work on something like this...? The bolts go through a sheet metal channel shaped radiator support. There's a piece of flat bar, probably spot welded to the inside of the channel, that's the hole that's tapped. The truck isn't restored. It's a repainted original and I'd hate to start butchering it up. Thanks, Jacques
| | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | If a dremel tool isn't handy and you have a hole all the way through a small round file works fairly well to recenter the hole. | | | | | Joined: Sep 2001 Posts: 208 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 208 | Yes, I hadn't thought of that. I was thinking that I could grind down a hacksaw blade to fit the hole but the round file idea and dremel are better ideas. Thanks, Jacques
