7 members (TrknGMC, Opelika Tom, Charles in CA, Otto Skorzeny, MikeE, Wayne67vert, TexasA&M48Truck),
64
0
Mod | | | Forums66 Topics128,091 Posts1,056,037 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | OK.. I feel silly...
How do you take the reverse lights off a 1966 stepside pickup truck? I never really looked at them too hard and just assumed there would be two outside screws holding the lens onto the light housing.
Nope... All I see is two self taping (wood like) screws coming into the fender from the inside of the housing.
I tried twisting the lens without any luck!
I did a search in the forms thinking someone had to come across this one... doesn't seem like it...
1960 Chevy Apache (C10) 1965 Chevy C30 Dump Truck 1966 Chevy C30 Tow Truck | | | | | Joined: May 2005 Posts: 227 'Bolter | | 'Bolter Joined: May 2005 Posts: 227 | I got them off... When the sun hit them just right, you could see "Twist off" with an arrow. I had to stick a screwdriver between the lenses and the case in a few spots to loosen them up, but with a lot of effort and a little help from one of those jar lid rubber things, they came off.
I am not sure if these are the original reverse lights. The inside state 1979. I looked at LMC trucks and found their reverse lights for stepsides. It looks like the original has two screws on the lenses.
Not happy with the rust I found behind the casing. So now it’s time to repair more rust... fun fun fun...
