0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#675628 09/05/2010 2:21 AM
jmh
Offline
My 48 Loadmaster has about a half round of play in the drive line. How much is too much?You can rotate the yoke on the rear almost 180 degrees before it engages the axles. It has a two speed. I think the play is in the reduction gearing where the two speed is located. I haven't removed the rear cover to inspect as yet. I don't have any weird noises to indicate a problem. Any ideas?
JMH
jmh #675634 09/05/2010 2:33 AM
Its probably a combination of slack in your side gears, your ring and pinion and the planetary gears in the 2 speed. If it isn't making strange noises, I would leave it alone. There is nothing you can really fix short of a complete rebuild.
crenwelge #675702 09/05/2010 1:38 PM
jmh
Offline
Here we go again.Against my better judgement how big a job is a rebuild and can you find parts should I dare to attempt this.
JMH
jmh #675709 09/05/2010 3:03 PM
I think parts probably could be found, but a complete rebuild is an expensive ordeal. If it were mine, I would look around for a used one with less slack and drive this one in the meantime. Used 2 ton farm trucks can often be bought for less than a rear end rebuild, and then you would have a bunch of spare parts. 46 through 51 uses the same third member. 52 and 53 can be made to work with changing side gears.
