0 members (),
61
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | My 48 Loadmaster has about a half round of play in the drive line. How much is too much?You can rotate the yoke on the rear almost 180 degrees before it engages the axles. It has a two speed. I think the play is in the reduction gearing where the two speed is located. I haven't removed the rear cover to inspect as yet. I don't have any weird noises to indicate a problem. Any ideas?
Thanks, JMH | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Its probably a combination of slack in your side gears, your ring and pinion and the planetary gears in the 2 speed. If it isn't making strange noises, I would leave it alone. There is nothing you can really fix short of a complete rebuild. | | | | | Joined: Mar 2010 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 79 | Here we go again.Against my better judgement how big a job is a rebuild and can you find parts should I dare to attempt this.
JMH | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I think parts probably could be found, but a complete rebuild is an expensive ordeal. If it were mine, I would look around for a used one with less slack and drive this one in the meantime. Used 2 ton farm trucks can often be bought for less than a rear end rebuild, and then you would have a bunch of spare parts. 46 through 51 uses the same third member. 52 and 53 can be made to work with changing side gears. | | |
