4 members (Brian Moore, Maybellene, J Lucas, Otto Skorzeny), 66 guests, and 3 robots.
Topics128,057
Posts1,055,808
#675350 09/03/2010 9:22 PM
i am restoring a '34 canadian gmc 1.5 ton flatbed dually (sp)...it has an open drive line w/ exposed universal joints...it is the only open driveline of the early '30s vintage i have seen and from what i can tell it is all original...no modifications...
does anyone have any insight regarding this design and know where i can find u-joints that fit...(there are no numbers on the u-joints)...will measuring the dimensions of the u-joints help...???...thanks all help will be appreciated...
couloir1 #675353 09/03/2010 9:40 PM
Originally Posted by couloir1
...where i can find u-joints that fit... will measuring the dimensions of the u-joints help...???...thanks all help will be appreciated...
Yep, measure the diameter of a cup and the length across the joint with cups installed, and note how they are clipped or retained in the yoke.
Then any good parts store should have them on the shelf.
If they stumble at first, ask to look at a Spicer 1350 series U-joint, just a guess, but I suspect that's what you have.
I'd buy a Spicer brand joint before any others, you may need to shop around to find a parts place that sells them, not all do.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
