| | | Forums66 Topics128,056 Posts1,055,800 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 10 New Guy | | New Guy Joined: Apr 2010 Posts: 10 | My 55 ¾ ton truck is starting to look like a super heavy duty. I am in the process of refreshing the motor and was just trying to figure out what I had for sure. From the below information I have found that all the major parts are from the year or close era. It is a ¾ ton truck built in Kansas City. The truck appears to be untouched aside from an old repaint that also replaced the lower front fender corners and patched what seem to have been dual antennas on the fenders. The front clip was removed but not painted under. The cab corners look like there is a little putty on them but no welding. The bed looks to have newer wood and stainless bolts. Nothing else seems to have been touched. While removing the drive line and such to remove the motor, all of the nut locking plates and cotter pins have never been removed and seem to be original. Even the motor mounts were in this condition. The truck is the 6900 GVW model. It has the HD 10 leaf rear springs. Everything appears correct until I get to pulling the motor. The parking brake is the lever actuated version that the Factory Assembly Manual shows only coming in the 3800 1 ton. The hole through the tranny cover looks stock. The motor and trans is green under all the gunk like it is a Load Master. I had to remove the transmission cover plate to remove engine and trans as a unit. The shop manual says this only needs to be done on the 1 ton and larger trucks. Anyone know if this is because of the HD 4 speed trans or because the trans hole is lower? The only difference between the Thriftmaster and Loadmaster I know of is the valves and piston rings. I don’t know how I would tell visually on the valves and I have not removed the pistons yet. The valve springs are a mustard yellow color. Not sure if that means anything about original or rebuild status. Is it possible the Load Master and heavy duty trans/parking brake could have been special ordered or came stock in the 6900 GVW truck? The 1 ton trucks had a GVW of 6200, 7000 and it was 8800 with dual rear tires. I also have not been able to find out what the SA means on the block number. Anyone have a more thorough list of those codes? Thanks, Mike
VIN: J255K018XXX Load Rating Plate: 6900 Block Casting: GM 10 – 3836233 CON 3 D 1 5 Opposite side: S 233 Block Serial: 0651708F255SA Head: 3835913 GM 24 Cam: GM 29 3836127 Trans: GM 591958 CON 5 1 E1O(5orS)
