1 members (klhansen), 129 guests, and 1 robot.
Topics128,151
Posts1,056,997
Members48,460
Apprentice
Apprentice
Engine will loose power when put under a laod, It acts like a fuel issue, have replaced coil,plugs,wires,fuel pump, could this be a carurator issue?
where is a good sorce on how to rebuild a rodchester RP Carburator?
I've got a similar issue with the 1955 235 that I've got in my 1951 Chevy 3100 5-Window. I've got Fenton dual intake and two Rochester carbs and I'm having a heck of time trying to get these things synced up. I'd almost bet your issue is carb related as is mine. Search the forum for Rochester Carb rebuild and I'd almost guarantee that you'll find someone that has documented this. You could also use www.google.com and search for Rochester carb rebuild. Best of luck!
