1 members (78buckshot),
112
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#67350 10/19/2006 4:05 AM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Quick question. Anyone know what the deck height above the piston is at TDC on the Chevy 235? If it matters, it's a 1959 engine.
I'm assuming 0.025", which is typical for Chevy V8's, but the stovebolt may vary from this.
I had to have my head shaved to get rid of a warp and the machinist knocked the maximum amount off, bringing combustion chamber volume to 69cc's. (I cc'd the chambers tonight). I had 84cc's previously. Assuming 0.025" deck height and 0.039" head gasket thickness, that gives me 9.10:1 compression. That's an improvement.
Anyway, anyone know the deck height above TDC? Thanks
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
#67351 10/19/2006 7:38 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | If the head is off you can measure the deck height with a straight edge and feeler gages. | | |
#67352 10/20/2006 11:52 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | From my experience with about four 235 and several 261 engines,the deck height with standard size original GM pistons is around .010-.015.Replacement original type aftermarket oversize pistons usually have the deck height at .025-.040 to allow for block and head milling I suppose. | | |
#67353 10/26/2006 4:42 AM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Yeah, that's what I show too. They're 0.040" overbored pistons, which makes it about 241 cubic inches. And with the shaved heads, I have about 9.25:1 compression now.
It's a modest increase, but that sets the stage for a few other modifications to improve how this 235 runs, such as headers and dual exhaust.
I guess I won't turbocharge this particular motor, since my compression is up this high. Maybe I'll worry about that on a future stovebolt.
The head's back on though. Hopefully now it'll run a lot better.
#67354 10/31/2006 1:50 AM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Well I got the 235 back together and started it. Initially, it ran well. I drove it for about 5 miles until it warmed up. Once water temp came up and the pressure built up, I started smoking like a steam locomotive again. Well, this time it's not the head. Water is definitely getting into the combustion somehow. I don't know if it's a hairline crack that I can't see that only sprays when my water pressure is up to 16 psi (yes, modern radiator), or if it's getting into the oil and the watery oil is getting past the rings. One way or another, I think I've eliminated every possibility but the block. And you know what? An increase to 9.25:1 made absolutely NO difference that I could feel in the seat of the pants. Still a weak, stupid boat anchor of an engine. I admire those who endeavor to keep these beautiful trucks original, but if I'm going to stay with a stovebolt engine, it's gonna need to be somewhere around or near 300 cubic inches, and possibly even with forced induction. Trying to get a 3/4 ton down the road on a little over 100 horsepower is horse dookey.
#67355 10/31/2006 2:37 AM | Joined: Feb 2006 Posts: 112 Member | | Member Joined: Feb 2006 Posts: 112 | you sure the heads not cracked, could be inside head where you can't see it. did you have it magna fluxed when it was off. | | |
#67356 11/02/2006 1:56 AM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Nope. And I'm not going to either. At some point I have to draw the line. I am sure the head and block could be magnafluxed, and the block could even be re-sleeved. But at the end of the day, I still have a 235 cubic inch engine making a bit over 100 hp, for the same amount of work and money it would take to rebuild a larger engine.
I found a website that sells rebuilt 292's for about $1200 bucks. GMPP sells brand new 4-bolt 350 engines starting at $1700 bucks. Either engine would make loads more power than a 235 for about the same money it would cost to rebuilt it. I have no problem parking the truck for a couple of months while I build up the cash I need.
