0 members (), 140 guests, and 0 robots.
Topics128,260
Posts1,058,343
Members48,485
#673313 08/26/2010 10:09 PM
Is there any way to test a temp gauge? Our 65 has gauges but the temp never moves. It has a new sender and I ordered one for a 65 with V-8 since we put in a 350. I think the old original gauge is bad.
'65 C-10, 65 L-60, 65 C-80, 72 C-60 & and a bunch of old Chevy cars.
Never time to do it right, always time to do it over.
Mearl #673316 08/26/2010 10:53 PM
I did a quick search. The temp gauge is a voltmeter, it's reading the rise in voltage as the temp sender resistance goes down. I didn't see the resistance for a 60s truck, but the later trucks use about 1400 cold and 50 hot. You should have voltage at both sides if the gauge, and at the sender. If you momentarily short the sender wire you should see the gauge spike.
Larry
I don't own a vehicle that isn't old enough to drink.
