| | | Forums66 Topics128,056 Posts1,055,798 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 12 'Bolter | | 'Bolter Joined: May 2001 Posts: 12 | I just got done reading a whole lot of topics in the search engine on swaping rear ends and pumpkins. I think I got all my questions answered except one topic. If I am going to use a rear end from a 76 Blazer will I need to change master clynder or any other brake pieces? I have a 50 GMC longbed I'm putting in a 307, 350 turbo and the 76 Blazer rear which I think is 3:73 gears. I can also possibly get my hands on a set of 3:07 gears. I'm a real rookie at this so any help would really be great. I'm looking to be able to hwy cruise 60-65 with out too much strain on engine. Thanks | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | Yes! If you go faster, you need to stop faster. Disc brake kits are available for the front as well as dual master cylinder setups. Last I checked it was a bargain for both at just under $700. These systems have been engineered pretty well and take a lot of the guesswork out of it for you. One caution is that these kits have some known problems that seem to be ignored. They require a bit of patience and sometimes some minor machining or fabricating to make work correctly. | | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I would recommend at least changing the master cylinder. The reason is that the original equipment only has one line coming out of it. There is no fail-safe. The new ones have two lines - one for the front brakes and one for the rear. That way if something goes wrong with, say, your rear brakes, at least you would still have front brakes - for a time - until the fluid all was pumped out. At least you could get stopped safely.
You didn't say what you are doing with the front brakes/suspension. Will it stay stock? If so, then I don't know about putting disks in back with drums up front. I have never heard of that before, and probably with a reason.
Good luck!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
