5 members (Otto Skorzeny, Ponchogl, walter74, Gray_Ghost, Napco Man), 95 guests, and 1 robot.
Topics128,055
Posts1,055,785
#672875 08/25/2010 5:26 AM
I just got done reading a whole lot of topics in the search engine on swaping rear ends and pumpkins. I think I got all my questions answered except one topic. If I am going to use a rear end from a 76 Blazer will I need to change master clynder or any other brake pieces? I have a 50 GMC longbed I'm putting in a 307, 350 turbo and the 76 Blazer rear which I think is 3:73 gears. I can also possibly get my hands on a set of 3:07 gears. I'm a real rookie at this so any help would really be great. I'm looking to be able to hwy cruise 60-65 with out too much strain on engine. Thanks
Mildman #672878 08/25/2010 5:44 AM
Yes!
If you go faster, you need to stop faster. Disc brake kits are available for the front as well as dual master cylinder setups. Last I checked it was a bargain for both at just under $700. These systems have been engineered pretty well and take a lot of the guesswork out of it for you. One caution is that these kits have some known problems that seem to be ignored. They require a bit of patience and sometimes some minor machining or fabricating to make work correctly.
I would recommend at least changing the master cylinder. The reason is that the original equipment only has one line coming out of it. There is no fail-safe. The new ones have two lines - one for the front brakes and one for the rear. That way if something goes wrong with, say, your rear brakes, at least you would still have front brakes - for a time - until the fluid all was pumped out. At least you could get stopped safely.
You didn't say what you are doing with the front brakes/suspension. Will it stay stock? If so, then I don't know about putting disks in back with drums up front. I have never heard of that before, and probably with a reason.
Good luck!
Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
