| | | Forums66 Topics128,188 Posts1,057,332 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | After doing a complete search of which I found many articles on the subject I couldn't find anything on installing the belts in the Art Deco style cab. I installed bucket seats in my 46 but installing the upper part of the belt on the door frame doesn't put the belt back far enough. I've even considered welding a mount on the upper back wall similar to a 4 point system. And yes the gastank has been relocated under the rear bed. Has anyone installed the 3 point belts in the Art Deco style cab. Suggestions would be appreciated.Thanks. Bobt
| | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Bobt, I haven't seen any 3point seat belts in an Atr deco truck. I have lap belts in mine, but you might be able to weld in some sort of bracket as suggested. The back wall isn't very thick so some reinforcement will be necessary. Another option if to find some bucket seats with the 3 point seat belt built in. I think a few buicks had them. I'm not sure about the width of these seats though. Let us know how it comes out. What ever you do. George
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I welded a piece of square tubing to the back belt line in mine and then welded a seat belt anchoring plate to that. Might be just a bit low but seems to be OK.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Thanks very much fellas, I think I'm going to have to weld in a bracket on the back cab wall and bolt the belt to it, seems to be the only way out,The seats are out of a mid size Oldsmobile and fit preety good.thanks again. | | |
