| | | Forums66 Topics128,021 Posts1,055,357 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Hello,
I am taking a trip in a couple weeks... about a 2 hour ride in a normal car. I found a set of tires for my vehicle. I have a 1946 Chevy Stylemaster Sedan. The tires I found are whitewall 4-ply tubed tires. The tires i have on the car now are rock hard bias ply straight line non-white walls. Only thing I realized is that I am not sure if I have tubes or not. If I do not have tubes can I still install these tires? Will the ride quality diminish significantly? I already have a nice vibration at 60MPH, I don't want it to get worse.
Thanks, Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder 1971 Chevelle SS 1995 Monte Carlo Z34 2005 Corvette Z51
| | | | | Joined: Jan 2009 Posts: 106 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 106 | Hard to give an answer with the information provided. It would be a good idea to take the tires you bought to a local tire shop and ask them to inspect the tires for safety and how to install them correctly.
Stovebolts are good for the heart
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Take a look at where the air valve is on your old Chevy and on one of your newer cars. The modern tubeless tires have a tire air valve that ends in a sealing doughnut on the rim. A tube type has a air stem that comes through a hole in the rim but does not have a doughnut seal. | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I'm not real sure I understand what you are asking. If you are thinking of reusing old tubes, don't do it. Tubes stretch with age and will make folds and leaks will start at the folds. Back when we still changed tires at our gas stations, more flats were caused by folded tubes than nails. Even if you are going to install used tires, install new tubes. Are the tires you are looking at tubeless. If they are, they will be marked as such. If they are tubeless and you had tubes, all you will need is tubeless stems. | | | | | Joined: Mar 2008 Posts: 10 New Guy | | New Guy Joined: Mar 2008 Posts: 10 | Most like the new tires you are thinking of buying are tubeless.
I just bought a new set of Coker L78s for my 59 Apache. No tubes. On the website they tell you if the tires require tubes.
The ride is pretty good, not as good as radials. Stiffer. But it does steer nicer at low speeds! And it looks killer.
- Joe
stupid like a fox art and junk: sandiegojoe.com
