3 members (66flea, Chris's 46 / 515, TUTS 59), 120 guests, and 2 robots.
Topics128,091
Posts1,056,445
Members48,443
I had coolant in the number 3 cylinder. I'm not sure yet if it was a blown head gasket or a cracked head. I've got the head off now and I cleaned up the number 3 combustion chamber with a plumber's wire fitting brush on a drill. I can't see any cracks, of course I understand that doesn't mean anything. It should be magnafluxed.
My question is... The valve seats on a 261 Chevy, are they inserted, or are they just cut into the cast? I've worked on mostly aluminum heads all my life, Honda motorcycles, etc, etc. And they have the seats inserted of a diferent material.
I have pictures of my project in my photobucket
Thanks in advance for any replys
ND1956Chevy6400,
My bet is always on the head gasket. You can 'read' a head gasket for leaks. If you haven't wiped it off, or thrown it in the garbage, inspect it very closely where any water jacket penetration could have crept through the gasket.
They usually will leave a small track, or will actually eat the head gasket material. You might see a rust track on the block or head too!
If you clean the carbon out of the combustion chamber, you might be able to see inserted seats...they would have a tiny line around them where they were put into the pocket in the head.
Stuart
I think they do have insert seats. My 235 did.
Bill Burmeister
All the original heads that I have seen (probably 50-60) have had seats cut directly into the head. But, at the age these things are now most have had multiple valve jobs. Often that requires new seat inserts to get the valve back to the right height.
If you find you have to add valve seats to the head, you might as well make sure they are hardened seats (but, maybe all seat inserts are hardened, now?).
Originals are just cast and machined into the head, although most rebuilt heads have inserts cut into them.
Paint & Body Shop moderator
