0 members (), 46 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#671800 08/20/2010 5:05 PM
U
U Offline
Hi,
I am sure this has been brought up before and I tried to search for it but unable to find.
Where can I find the torque settings for all the bolts and nuts on my 1957 Chevy 3100?
Thank you!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
UnklRod #671804 08/20/2010 5:23 PM
torque specs are basically for driveline areas, be in the different sections of the shop manual, if you're thinking of body parts/sheet metal, lock washers take care of that where necessary, just make sure they're all "snug"
squeeze #671809 08/20/2010 6:14 PM
U
U Offline
Hi Bill,
Yes I was mainly looking for front end, springs, running gear...Don't want things falling off as I go 50 down the hwy.
More pix
UnklRod #671819 08/20/2010 7:02 PM
where specific torques are required they'll be toward the end of each section of the manual, otherwise tighten things until the split washers are barely flattened out, then the "tooth" at the split will dig in enough to prevent loosening
squeeze #671832 08/20/2010 7:43 PM
U
U Offline
OK,
Great! Thank you.
More pix
UnklRod #671951 08/21/2010 5:53 AM
I use the German Torque Specs.......
Goodt and Tight! grin
GMC: Get More Cash...
1958 GMC
My Webshots photos
Remember......
Lefty Loosey.....
Righty Tighty.... grin
1958 GMC
My Webshots photos
