| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | Did some searching but did not find what I was looking for. Are the running board brackets the same for a 1/2 to 3/4 for AD trucks? These would be the brackets riveted to the frame.
Thanks for any information...Eric | | | | | Joined: Jan 2008 Posts: 176 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 176 | Hi Eric, Here is a page from the master parts catalog. http://chevy.oldcarmanualproject.com/1929_57chevyparts/57cmpc0569.htm It looks like the front brackets are the same 1/2 and 3/4 ton but different front left and right. Same part numbers for middle bracket left and right. But for the rear, it looks like a different part number for 1/2 and 3/4 ton. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Did some searching but did not find what I was looking for. Are the running board brackets the same for a 1/2 to 3/4 for AD trucks? No, the front two are the same but the rear ones are different to accommodate the extra length of the RB. The half-ton's are angled foreword. The 3/4 ton's are straight. In the Facory Assembly Manual there are plan views of frames where you can see the exact dimensions. | | | | | Joined: Jul 2005 Posts: 169 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 169 | You guys are great!!!
Thanks for the information...Eric | | |
