| | | Forums66 Topics128,127 Posts1,056,357 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 2 New Guy | | New Guy Joined: Jun 2008 Posts: 2 | I know the profile of my new foam door gasket, for 46 chevy pu, the groove goes up to get rain to run around and down,...but does the long vertical leg face the inside of the door edge or the cab opening? My truck had none to compare and I've found no answer in parts and rubber catalogs. (I suspect the long leg is to the inside door edge). I don't want to glue it on the wrong way. Can anyone help? Thanks! | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hi Curt. I think you '46 is same as my '40. The flat part ( vertical leg ? ) is pinched between the body and interior trim pieces. Only the " bulb " part is exposed. The door closes against this to seal the opening. | | |
