4 members (JW51, Mike Burns, MRMEROTH11, KEVINSKI), 121 guests, and 2 robots.
Topics128,133
Posts1,056,395
Members48,441
#671451 08/19/2010 2:50 AM
I know the profile of my new foam door gasket, for 46 chevy pu, the groove goes up to get rain to run around and down,...but does the long vertical leg face the inside of the door edge or the cab opening? My truck had none to compare and I've found no answer in parts and rubber catalogs. (I suspect the long leg is to the inside door edge). I don't want to glue it on the wrong way. Can anyone help? Thanks!
Hi Curt. I think you '46 is same as my '40. The flat part ( vertical leg ? ) is pinched between the body and interior trim pieces. Only the " bulb " part is exposed. The door closes against this to seal the opening.
1940 Chevy KC 1/2-Ton
